Farmall A missing on 1 4
Posted by chad from michigan on July 08, 2011 at 17:48:36 from (64.119.55.128):
Went to cut grass at my dads today and the tractor is running crappy. missing really bad changed all plugs and runs the same. Grounded out the plugs to find out 1 & 4 are not firing.
Changed the plug wires and still same problem.
I tried adjusting the points and they were real close to .013" its a mag. could I have problems with the dist cap? or bad points and condensor? what should I be looking at? any help would be great.
Thanks
