Re: Farmall A missing on 1 4
Posted by JRSutton on July 08, 2011 at 18:28:17 from (75.130.109.233):
In Reply to: Farmall A missing on 1 4 posted by chad from michigan on July 08, 2011 at 17:48:36:
haven't done much work on these myself, so can't help much - but if you rotate the engine by hand, can you hear a strong click when 1/4 should be firing? (tdc on 1/4)
If so, it generally means you should take a closer look at the points, clean them up, see if there's anything going wrong there.
If it doesn't click, you might have bigger problems.
