656 Starter ?
Posted by TimWafer on July 09, 2011 at 11:28:49 from (69.193.106.146):
I need to replace the starter drive clutch and the ring gear on the 656 I just acquired. Having a hard time figuring out which part #s I want. The tractor is a Farmall 656 Hydro Diesel. Seems to be a number of different combinations and I not sure that the ones on it were even correct or a matched combination, hence the problem. I cant find a # on the starter anywhere. Where should it be? Any help appreciated!
Thanks
Tim
