MCV Valve
Posted by farmall706 on July 09, 2011 at 16:19:17 from (50.103.0.171):
I am working on my 706 MCV Valve. Latest findings are: I put a pressure gauge in the sensor hole on the MCV. I get 0 pressure? I ran the tractor around with the gauge in there and never got any pressure to show on the gauge. I had the T/A forward. The gauge goes from 0-100 PSI, it just sits at 0 with full throttle, adjustment bolt moved in and out, clutch out. My steering is fine. The one thing I do notice is when driving the tractor and you push the clutch in and let it back out before the tractor comes to a stop, the tractor acts like the clutch is still pushed in, then it will grab and go. but if you apply a little brake it engages and takes off? Any other tests I can check? Any thoughts are appreciated. Thanks for your time.
