Posted by pete 23 on July 09, 2011 at 18:37:16 from (74.32.234.149):
In Reply to: MCV Valve posted by farmall706 on July 09, 2011 at 16:19:17:
How are the brakes. Sounds to me like you are operating without any regulated pressure and actually in low range on the TA and free wheeling with clutch pedal in until sprag catch's up and takes ahold. At any rate , you need to check the regulated pressure with a 300 psi gauge at the bottom rear port of mcv. You should have about 240 to maybe 270 psi in high ta and low ta and a 15 psi drop when the ta lever is in between high and low and go from there.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
