1953 Super H not running will
Posted by burnsg2003 on July 09, 2011 at 20:01:06 from (64.12.116.73):
I have a Super H that has always run great. Yesterday while using it to rake hay it almost seemed like it was running out of gas. I barely got it back home. I checked the points they seemed to be correct. I tried adjusting the carb. It will set an idle beautifully at idle. I rev it up and it almost dies then it seems like Its going to run ok the acts like its going to die again. I am guessing I have some dirt in the carb.My dad says it is the valves but I don't think they would be the problem that suddenly. Also, since the carb is hooked to the govenor do you loosen it at the carb or at the govenro end which is best thanks in advance for your help.
