What you found was the old graphite-block bearing. It did not turn. The grease fitting was only to lube its carrier along the shaft.
If you're changing ANYthing (as in block, clutch, machining the flywheel . . .) it will be worth your while to spring for the newer-style thrust bearing and the carrier to hold it. Those graphite bearings worked beautifully in a new installation, but their performance was based on the way they would "wear in." Change anything, even just a whit, about the geometry of the way the clutch fingers meet the face of that graphite block, and you'll tear whole chunks out of it, and wind up having to re-split anyway.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
