Re: Heat riser unit on new 560 manifold
Posted by Bob on July 10, 2011 at 22:43:36 from (64.255.159.192):
In Reply to: Heat riser unit on new 560 manifold posted by redgems on July 10, 2011 at 22:30:45:
You have a failed OEM manifold, RIGHT?
And a NEW aftermarket manifold you saved big bucks on, right?
You need to look at what's left of the OEM manifold to see how everything fits together, then EARN the savings you got on the manifold transferring over what you have learned/observed to the new manifold!
