Heat riser unit on new 560 manifold
Posted by redgems on July 10, 2011 at 22:30:45 from (107.24.117.127):
Gentlmen, I purchased new after market intake manifold for 560. It came with heat riser parts but no instructions. There is a rod,flap,spring,and butterfly weight. How do you attach flaper to rod? weld it? and how do you align weight to flaper ? is it streight or off set? and attaching spring? whats the relation of the slot on end rod end to flaper and pressed on wieght? Also after all is lined up and ready How in hell do you press shaft to butterfly weight in place when there is a manifold flange next to it. WOW! if you can answer any of these questions ,you guys are much smarter then I. Thanks in advance, Tony
