Re: Super MD engine miss/popping
Posted by Dan MD on July 12, 2011 at 07:56:33 from (207.118.245.10):
In Reply to: Super MD engine miss/popping posted by Dan MD on July 12, 2011 at 06:59:23:
I pulled the air cleaner apart and cleaned that all up. Haven't checked the intake manifold.
I had the pump and injectors completely redone by Dubuque DIS.
When I set the valves, I didn't see a broken spring. Do I need to pull the push rods out completely to rule out a bent push rod? I never pulled them out. I just looked at everything as I turned it over and didn't see anything unusual. I was able to set the lash easy enough without having to adjust them very much.
Thanks,
Dan
