That is probably your problem. That is the grounding switch. Usually the wire gets rotten and it will ground out all the time. Not sure about a coil system/how they did it, but it is a pretty common problem on a mag system.
When I had a VAC that didn't run I could chase the power through the coil and found it was past the coil and in/near the condenser. You could possibly use the tester in a manner like that.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
