Re: Super WD9 no start gas
Posted by bigduke0767 on July 13, 2011 at 14:26:54 from (173.188.51.160):
In Reply to: Super WD9 no start gas posted by rustred on July 13, 2011 at 12:12:49:
I did file the points and checked the gap. It's been about a year that it ran on gas. I also switched the coil with one that for sure works. Also there was a wire that ran from the switch to the plate on the manifold that was in bad shape so I switched that out as well.
