Re: Super WD9 no start gas
Posted by Janicholson on July 13, 2011 at 19:06:14 from (67.72.98.45):
In Reply to: Re: Super WD9 no start gas posted by bigduke0767 on July 13, 2011 at 14:26:54:
With a distributor, the wire to the manifold should be at battery voltage when the tractor is in the Gas start mode. If not, a plain toggle switch can be used to feed the coil when starting, then shut off when running. This will at least identify the issue. Jim
