When I cracked the injector bleeders before I noticed that each one seemed to affect the motor the same, but I was looking for a bad injector at the time and might not have noticed a change in the popping as much as I noticed the motor "bog down" with each bleeder cracked.
I turned the motor over with the valve cover off and everything looked good as far as all valves going up and down and no broken springs. The starting valves all appear to be closing.
I did find one thing that may be an issue. I measured each valve at the same spot on top of the spring rotator. I didn't get the same amount of travel from up to full compress.
My readings are:
1 exhaust - .40 1 intake - .45
2 exhaust - .37 2 intake - .46
3 exhaust - .40 3 intake - .45
4 exhaust - .42 4 intake - .46
Assuming I set the valve lash correctly, could this mean I have cam lobe wear on #2 Exhaust? Would this be enough of a problem to cause the popping?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
