Re: Farmall 350 power steering problem
Posted by pete 23 on July 14, 2011 at 16:07:38 from (74.32.234.149):
In Reply to: Farmall 350 power steering problem posted by Dean Olson on July 13, 2011 at 21:18:17:
If it is a factory Behlen unit it is likely the roll pins in the steering control valve. Some may be broke or just worn badly. You can still get gaskets and seals for that unit but no doubt the input shaft will be worn and will have to be built up as I doubt if that shaft would be available or affordable. Of course, make sure it isn't in the worm or ball bearing on front end of worm shaft.
