I figured the hydraulic was low because I thought it wa finaly filled up the system. I just put the loader on it and when I put it on it was empty and it only took one gallon to fill it up so I thought it was just low because it got the air out of it and filled up the cylinders. I will keep an eye on the oil level I just changed the oil today. so if it keeps up check the pump o-rings? the two that go on the lines as it goes in the block? I did have to take the hard lines out to drill out the pipe plug on the other end and maybe I messed up the orings. Chad
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
