Re: Ih-1000 loader return hose pulsating
Posted by Hendrik on July 15, 2011 at 00:12:52 from (194.53.253.51):
In Reply to: Re: Ih-1000 loader return hose pulsating posted by chad from michigan on July 14, 2011 at 17:40:04:
What Oldiron29 means is the O-ring or seal (depending on the pump) that seals the pump shaft. You will have to remove the pump to get to that O-ring or seal.
You may also look in the archives since this is a topic that has been discussed many times; ElToro posted a parts diagram of the pump.
HTH, Hendrik
