Re: Mccormick Deering 10-20 carb and mag help needed
Posted by 36F30 on July 15, 2011 at 21:31:31 from (71.214.211.46):
In Reply to: Mccormick Deering 10-20 carb and mag help needed posted by fordpower30 on July 14, 2011 at 21:07:31:
Initial settings by the book for the model R carb on the 10-20 are: the fuel adjusting screw on top of the carb out one and a half and the idle mixture screw on the bottom out two and a half
If you installed a new needle and seat to lessen your fuel bill, does that mean it was leaking fuel? are you shutting off the fuel petcock every time you shut down the engine? That carb is not designed to, or capable of holding back the fuel when the engine is not running.
I'm looking for the timing procedure for the bosch, I think I have it somewhere.
