Mccormick Deering 10-20 carb and mag help needed
Posted by fordpower30 on July 14, 2011 at 21:07:31 from (97.107.61.160):
Hello,
I have restored a "29 10-20 about 4 years ago. Since then I have had problems with the carb and mag.
I have the mag firing good at TDC, but when I advance the timing it seems to be going to far. It has a Bosch Mag. (i think e4b??)
Also, I installed a new needle and seat in the carb to lessen my fuel bill... but now I cannot get it to start. It seems to have too much fuel on choke, and not enough open. I checked all the gaskets, which seem OK. idle needle is 2 1/2 turn out, fuel needle is about 1/2 turn out.
I have no luck with carbs, any help is greatly appreciated.
Thank you,
Tyler Martin
