Re: Saved sickle mower
Posted by Lmack on July 18, 2011 at 19:41:57 from (72.145.196.199):
In Reply to: Saved sickel mower posted by Rick Remmert on July 17, 2011 at 19:57:47:
Looks like the rod ties into the touch control level rod. Pardon me that I do not know what it is called, but we had one on our 200 and there is place for one on your SC. If you look at the level stabilize pin the vertical bar has a very similar construction to your bar pin. Only problem is that I do not see how it would be mounted. The bar from the touch control to the level adjustment bar from the touch control flops around if not attached. You may have a peace missing that would bolt to the axel housing. Otherwise, the adjustment bar does lay on the axel housing and that may be all that is needed. If you have the bar I am talking about (needed for bottom plows etc.) then give it a try. If not you may need to get you hands on one. Someone else will know what it is called. If you need a pix of the bar, let me know because I have one for the 200 out in the shed. Send me an email and I will send you the pix.
I have a 2 point sickle mower that has the drive directly over the sickle drive. It also has the right axel attachment you mentioned. Do you know the model number for my mower. If so, shoot me an email so I can be looking for parts. Thanks.
