Re: 560 diesel engine swap to 706
Posted by mkirsch on July 19, 2011 at 10:44:59 from (64.80.110.75):
In Reply to: 560 diesel engine swap to 706 posted by D1206 on July 19, 2011 at 06:21:18:
You know, I wouldn't sweat the small differences.
The 706's injection pump is probably shot right along with the engine. The 560 engine presumably has a perfectly good injection pump.
You can easily get 75HP out of the 560 engine by turning up the pump a little. But, you probably don't even need that much power for what you'll be doing with the tractor anyway, right?
The only issue I see is you might not be able to get 540RPM out of the PTO with the slower-turning 560 engine. PTO engine speed on the 560 is 1800RPM, but it's 2100RPM on the 706.
