Re: 400 diesel part 2
Posted by D Slater on July 19, 2011 at 18:28:27 from (184.15.41.100):
In Reply to: 400 diesel part 2 posted by Workman on July 19, 2011 at 12:31:42:
Can't remember exactly how all the parts are placed, but B primary pump has the bypass valve that I think you mention. Small hole is a passage to the suction side of the primary pump. Any fuel that leaks past the distibutor valves is supposed to be sucked in. If a original gasket is between injection and primary pump it has a small hole for the passage both ways its installed. If someone made a gasket the holes may not be open to each other.
Sump oil can get to the primary pump drive end.
