400 diesel part 2
Posted by Workman on July 19, 2011 at 12:31:42 from (206.251.11.28):
Ok I pulled the primary pump off today and bench tested the pump. It'll prime and pump if I hold my finger over the small hole that faces the injection pump. I'm not sure what the purpose for this hole is. I know on the inside of the pump there is a seat and needle valve w/ a spring the corresponds to the hole. Also when I pulled the primary pump out a good bit of oil came out of the injection pump where it bolts to so I would assume that the primary pump would have been sucking oil through that little hole out of that cavity.
