Re: 100 hydraulic pump questions
Posted by gene bender on July 20, 2011 at 06:01:26 from (207.177.56.53):
In Reply to: 100 hydraulic pump questions posted by chad from michigan on July 20, 2011 at 03:32:19:
You wont know which seal you have until you take the pump apart. It is either an o-ring or a seal. If the shaft is worn where the seal rides you will need a speedy sleeve to get that part of the shaft back to original as the new seal riding in the grouve will not last.
