Re: 100 hydraulic pump questions
Posted by chad from michigan on July 20, 2011 at 06:38:55 from (151.163.2.8):
In Reply to: Re: 100 hydraulic pump questions posted by gene bender on July 20, 2011 at 06:01:26:
just to get this correct I need to replace the seal under the front drive gear correct?
Its a HPI-1-89 CR seal under the drive gear.
I have a bearing house not far from work can I just take the seal there and get a new one?
Chad
