Re: 6V charging system
Posted by El Toro on July 20, 2011 at 11:20:33 from (108.15.86.54):
In Reply to: 6V charging system posted by Dave H (MI) on July 20, 2011 at 09:18:39:
Take a volt meter set on dc volts and measure your charging voltage across the battery terminals with the engine at 1/2 throttle or better. Should be around 7.2 volts to charge a 6 volt battery. Hal
