Hold your hand over the throat of the carburetor while a helper try's to start the engine and see if you have good suction on your hand. Weak suction means low intake manifold vacuum. Weak vacuum could be caused by stuck rings, valves not seating to name a few. Hal PS: I would try to pull start the tractor if you have another tractor.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
