Super H - want to hear it run wont start!
Posted by Farmall Bob09 on July 20, 2011 at 18:48:24 from (75.213.211.209):
hello guys...need a person(s) to tell me what I need to do to get my super h running. it has been sitting a good many years. the engine was set up. I have it freed up now. Has new plugs, wires, points, condenser. rotor button. I have spark. Carb has been rebuilt, I have cleaned it thouroughly! been apart a bunch of times. Valves are working. made sure that they first worked by pushing on them. then took valve cover off and watched them move....all do. cant get the tractor to even pop. manifold was taken off and all the crud was blown out of it, intake and exhaust....reinstalled and is tight. fresh gas, sediment bowl is clean. good supply of gas to the carb. i dont have a screen installed at the carb. carb bowl is filled up, however u can crank and crank and then take out the plugs and they are dry. dont beleive it is getting gas. like i said carb has been apart numerous times! have good suction. do i have a valve problem even thou the valves are working? any ideas? i have also tried giving it a whiff of ether in the end of the carb....nothing....just like it is not getting to the plugs. please someone help. thanks in advance.!
