Re: Super H - want to hear it run wont start!
Posted by JRSutton on July 21, 2011 at 11:58:55 from (69.3.169.162):
In Reply to: Super H - want to hear it run wont start! posted by Farmall Bob09 on July 20, 2011 at 18:48:24:
I'd suspect that you maybe didn't try hard enough with the ether, and the problem is in the carb.
You said you have a good spark, do you have a spark to each plug?
If it's not even firing with ether, and you're sure you're getting a spark on all cylinders, AND you can feel some suction at the carb, it almost has to be that the timing is way off.
Seems unlikely though, as you didn't mention anything that would have changed the timing since it last ran. But even so, I'd at least eyeball it to be sure it's right.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
