Right now i have the tires and rims off the front end because they were flat and weather checked..when I get ahold of a set of tires I will try pull starting it. I do have spark at each cylinder. I have the wires hooked up right on the cap and to the plugs. However I will recheck that the rotor points to number one plug tower on the tdc of compression stroke at cylinder one. Thanks for all of the input. I will get back to you guys and let you know what I found. Appreciate the help!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
