Re: Super H - want to hear it run wont start!
Posted by El Toro on July 21, 2011 at 14:16:14 from (108.15.86.54):
In Reply to: Super H - want to hear it run wont start! posted by Farmall Bob09 on July 20, 2011 at 18:48:24:
Check your sparkplug wires to make sure you have them in the correct firing order on the cap and that they're going to the correct corresponding
sparkplug. You may have fire to your plugs, but
it may not be firing at the right time. Your plug wires should be in this firing order on the cap:
2-1
4-3 Since the rotor rotates Clockwise.
You should also bring No1 piston to TDC on the compression stroke by removing No1 plug near the radiator. Hold your thumb over the plug hole while a helper hand cranks the engine over slowly until you pressure against yoiur thumb.
Once you feel pressure against you thumb drop a long plastic straw on top of the piston and you watch the straw rise as the helper keeps cranking the engine until the straw quits rising.
Your No1 piston should now be at TDC on the compression stroke. Remove the cap and see where your rotor is pointing. It should be pointing to the No1 plug tower. If it is at the No1 plug tower your engine is in time. If its off you need to pull the distributor or mag and rotate the rotor so it is at the No1 plug tower and reinstall it. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
