Re: 756 questions
Posted by CDB on July 22, 2011 at 14:11:07 from (216.229.21.13):
In Reply to: Re: 756 questions posted by The tractor vet on July 22, 2011 at 06:22:45:
I've read your previous posts regarding the low ash oil and high octane gas - I will keep that in mind going forward. I guess that I am not convinced that a valve is burnt. I was wondering what some symptoms would be. It seems to run fine once it gets past idle.
The local mechanic set the points and timing...i just did the easy part...plugs and cap, air filter, etc. I was wondering if maybe the timing and/or points are not gapped right. I think he knows his stuff, but, I have a slight feeling that he isn't being straight with me. Not sure if he is just trying to get more business...
Is there something i can use that will help the valves..if they are gummed up or sticky..not burnt? The seafoam through the carb seemed to help some...
