Re: 756 questions
Posted by The tractor vet on July 22, 2011 at 06:22:45 from (75.19.127.83):
In Reply to: 756 questions posted by CDB on July 21, 2011 at 18:47:07:
Ya can run a compression check of each hole and that will tell ya. And the main reason for a burnt exhaust vale is the wrong engine oil being used . use ONLY a low ash 30 w in I H gas tractors . Use only 93 octane gas in them. That is the minim octane that should be used in them. when they were new reg gas was 95 octane and high test was 105 and up some of the cheaper grade were around the 93 back then . Ing. timing is most important on the later 4 cylinder and 6 cylinder engines and you set the timing at high idle . Your best friend for this tractor is and owners manual and atleast and IT manual. Your fuel requirements and oil requirements will be covered in the owners manual , tune up info in the I T manual . Clutch adjustment and stuff like that will also be covered.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
