Farmall H -Brake cover, shaft, brake drum seals
Posted by AL Moyer on July 24, 2011 at 15:09:13 from (173.62.239.147):
Posted back in the begining of June about cover removal, got the cover off, but separated bushing from the cover as it was rusted to the shaft, & then got the shaft out of main block. Not sure if the shaft & brake band mechanism is savageable or not, are these available new ? Also, looking for the drum shaft seals, seem that the replacement ones aren"t as deep/thickness as I see mention of installing 2. Anyone know a part # of these seals, I have a bearing,seals & drives supply store near by. I"m sure I"m not going to get the seal out without destroying it, & I don"t beleive taking off the bearing plate retainer (?) off to tap the old seal out is a good idea. Thank, Alan
