Re: Farmall H -Brake cover, shaft, brake drum seals
Posted by Tom Fleming on July 24, 2011 at 17:57:59 from (67.20.249.95):
In Reply to: Farmall H -Brake cover, shaft, brake drum seals posted by AL Moyer on July 24, 2011 at 15:09:13:
I just went through this same exercise about 6 months ago. NAPA has the seals, and I used just one, but 2 certainly doesn't hurt anything. Look for the seal number on the CIH web site. Then go to the NAPA online site, and in the upper right hand corner, there is a cross-over link. Enter the CIH number, and it will return the NAPA number.
I used anti-seeze on the brake pivot axle. Use battery terminal felt washers for the dust seal on the brake pivot axle.
Lastly, if your brake bands still have decent life in them, but are oil soaked, use a propane soldering torch to "cook" off the oil. Don't get them too hot. Final rinse with brake-clean, and scuff the surface with 100 grit sand paper.
