Re: pepper again;;
Posted by JRSutton on July 25, 2011 at 06:05:21 from (75.130.109.233):
In Reply to: pepper again;; posted by blunted on July 21, 2011 at 18:42:09:
Obviously the right gasket needs to be used for proper cooling, etc.
But also, a very common mistake is to not use sealer on the threads of the head bolts, or not use enough.
I'm not 100% sure the threaded holes in the block go into the water jacket on this particular engine, but I'm assuming they do.
Although I'm suprised nobody else mentioned this, since it's such a common mistake - maybe they don't??? Or maybe it was discussed in the other posting which I have not seen?
Either way, the best gasket in the world isn't going to keep the coolant out of your oil if those threads aren't sealed properly. They WILL leak without it.
Use a good sealant specifically designed for the purpose.
