Re: Farmall H Power Coupling
Posted by Mike1972chev on July 27, 2011 at 09:38:26 from (75.149.81.173):
In Reply to: Farmall H Power Coupling posted by matt1983 on July 24, 2011 at 17:59:13:
I just did mine on My Super M.It is all available.BUT the bolts were "out the roof" on pricing.
I welded the "worn spots" on the tapered bolts,Dressed them perfectly with a die grinder with a sanding wheel on it,and then re installed them with the orientation of the bolt 90 deg from where it originally rode against the couplers.(In other words,where the worn spot of the bolts WAS driving against the coupler,it NOW is riding against a NEVER USED part of that same bolt.Even though I repaired the gouging. :)Unless the bolts are almost worn in two,I would highly reccomend doing it this way.Those tapered bolts are expensive!!!!
