Farmall H Power Coupling
Posted by matt1983 on July 24, 2011 at 17:59:13 from (71.234.106.161):
I recently bought an H that had a rattling coming
from the center section near the belly pump. I
took of the inspection cover and found that the
coupling between the shaft from the engine to the
transmission was loose. The took it apart to find
that the bolts are worn and the holes on the metal
coupling piece are elongated. The rubber bushings
also fell apart as I took it apart. I've been
searching online and cant find new parts for this.
My question is are these parts available new still
or will these parts have to be found used? Thanks!
