Re: Farmall H Power Coupling
Posted by Owen Aaland on July 27, 2011 at 13:22:21 from (216.47.33.9):
In Reply to: Farmall H Power Coupling posted by Goodman on July 24, 2011 at 17:59:13:
The rubber washers are probably the most important parts for noise reduction. You may need to shim them a little between the steel cup and the rubber washer to make sure they are tight. You can make shims from gasket material.
