Re: TWO PROBLEMS, HELP
Posted by Bob M on August 12, 2000 at 19:55:12 from (205.188.200.29):
In Reply to: TWO PROBLEMS, HELP posted by VINCE on August 12, 2000 at 18:55:21:
Vince - Did you retighten the packing nut after you ran the tractor a while? New packing has gotta "seat in" when first installed requiring adjustment (tightening) of the packing nut once or twice for it to seal.
Regarding governor not picking up the load, if you've got a new governor assembly installed then the problem has gotta be either adjustments or a binding throttle shaft in the carb. Check for free movement of the throttle shaft (remove the cover from the governor riser, then with the governor handle set at "idle" make sure the bellcrank moves easily). Then follow the instructions in an I&T manual to set the governor handle, low and high speed stops and carb bellcrank link adjustments - your problem should clear up.
Good luck!
Post A Followup
: Re: Re: TWO PROBLEMS, HELP
