Re: cub 154 solenoid clicks won't turn over
Posted by kossuth on July 29, 2011 at 05:12:37 from (214.3.115.10):
In Reply to: cub 154 solenoid clicks won't turn over posted by pheel on July 28, 2011 at 14:55:19:
Quoting Removed, click Modern View to seeOk, here is what I remember without running to my folks place and looking at the M we rewired. The "i" terminal is supposed to go to the coil on ford vehicles, I think this is unneeded if you are wiring the coil individually. The "s" terminal is what is supposed to come from your ignition switch and it is supposed to be a 12v feed. The large terminal on the side by the "i" is where your battery feed is supposed to be coming from and the side by where your "s" is is where it departs the solenoid and goes to the starter. This thing has got to be grounded. So make sure you have a good ground on the mounting tabs or it won't click over.
