Re: Farmall 200 starts then dies
Posted by Dave_Id on August 01, 2011 at 12:03:34 from (75.92.58.173):
In Reply to: Farmall 200 starts then dies posted by Alex829 on August 01, 2011 at 11:56:04:
Gas starved. More than likely from the tank to the carb. Remove the plug at the bottom of the carb, to see if you have a strong continuous flow. If you have a good flow, then it might be dirty carb itself. I'm assuming here that you have replaced the old gas with fresh. Old gas don't burn too well. If you have poor flow, look to the bowl, and the screen in the bowl. Crud in the tank may have plugged the opening out of the gas tank... It could be many things.
