Agreed - if it's running on starter fluid, but not on its own - it almost certainly means it's not getting enough gas for whatever reason.
(assuming you have good gas and no water)
Usually, if it does run for a short while before becoming starved of gas (or runs at low speed but not high speed), it means the gas is getting through the carb just fine, but isn't getting into the carb fast enough. Check the lines to the carb - if not blocked, check your float and needle valve.
If it's just running on starter fluid only, and dying immediately afterwards - that usually means all of the above, or that gas isn't getting through the carb into the cylinders. That usually means passageways in within the carb are blocked.
Either way, if your fuel line is clear, your carb probably needs a thorough cleaning.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
