Re: cleaning out an H transmission/rear end
Posted by pete 23 on August 01, 2011 at 17:29:18 from (74.32.234.149):
In Reply to: cleaning out an H transmission/rear end posted by Brad in WI on August 01, 2011 at 16:09:46:
What I used to do some times was save the hy-tran that I was changing in a newer tractor and use that. A Magnum hold about 40 gals so you can get a lot of flushings with that. We had a filter on the holding barrel though no "large contamination". On an older tractor that is all gunked up I would fill her up and go for a ride down the road in high gear.
