cleaning out an H transmission/rear end
Posted by Brad in WI on August 01, 2011 at 16:09:46 from (184.95.100.226):
What can I use to clean out all the gunk, old gear lube, and god knows what else? I have used diesel fuel or Kerosene in the past, but is there a better or cheaper way to remove all or at least most of the sludge? Thanks
