Re: cleaning out an H transmission/rear end
Posted by DanR on August 02, 2011 at 04:59:23 from (67.236.1.105):
In Reply to: cleaning out an H transmission/rear end posted by Allan In NE on August 01, 2011 at 16:09:46:
If you are near a place that works on jet aircraft you're probably in luck. The fuel, JET-A, has to be drained before the engine can be worked on. Sometimes it is less costly to replace the fuel than to clean it. There is also a problem disposing of the fuel so they give it away. Great cleaner.
