Re: Farmall M block question
Posted by John M on August 02, 2011 at 07:13:43 from (68.115.194.228):
In Reply to: Re: Farmall M block question posted by Adam F on August 02, 2011 at 05:01:14:
I don't think the date code could be an R, and be older than the tractor That would put it back before 1939, when the M came out. R would be 1948, and B you know, is 1956.
I have 2 Ms with IH replacement engine, both have the B code, and nothing is ground off on the casting date, BUT the block part numbers are ground off of each, except for the letters, which I don't recall at the moment.
