Re: Farmall M block question
Posted by Adam F on August 02, 2011 at 05:01:14 from (74.92.241.209):
In Reply to: Re: Farmall M block question posted by D Slater on August 02, 2011 at 04:51:45:
Mr. Slater, thanks for the help. it does have that little 2 bolt cover on the carb side of the motor, and a hole just above the oil pan in the block with a pipe plug in it in the distributor side. the date code ends with either R or B, its also been just about ground off. If its an R that makes the block older than the tractor but if its a B thats 1956?
