Posted by elroysdad on August 02, 2011 at 07:27:47 from (69.66.252.163):
In Reply to: F20 help please posted by elroysdad on August 02, 2011 at 05:50:11:
Should the mag gears should be timed by having the dot on the rotor gear going between the two flat bevels on the other gear? Also, where would be a good starting place for load and idle screw settings? At #1 tdc are the dogs on the mag coupling supposed to be straight across? I will check compression on all four tonight after work. What would be a reasonable compression number for each cylinder on an engine that hasnt run for more than a minute in the last 15 years? Thanks, John.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
