Re: F20 help please
Posted by JRSutton on August 02, 2011 at 08:21:35 from (75.130.109.233):
In Reply to: Re: F20 help please posted by elroysdad on August 02, 2011 at 07:27:47:
At this stage you just want it to start, so you just want to be sure nothing is WAY off. Like no compression in one or more cylinders.
If all the cylinders are in the 80 range or more, and hold some pressure for a little while you should be fine.
As others have said, you can put a little oil in each cylinder to boost the compression while starting. That could help.
But I'd still try a blast of starter fluid first to see if it does anything. If it does, that'll tell you a lot.
